Second characteristic write wont be received (From Android)
I am using an Android application to send data to a nRF52 board. The nRF52 board is the peripheral and the Android phone is the central. This is the link establishment process:
  1. Connect
  2. Negotiate MTU
  3. Discover services
  4. Enable notifications
Then we are using writeCharacteristics (and onCharacteristicWrite) and onCharacteristicChanged to send an receive data. This works quite well, but sometime i end up in an unrecoverable state where i have to restart Bluetooth on the phone to make it work again.
At this point, I am able to set up the connection, and send the first chunk of data. Then after this, i receive some data, but when sending the next chunk, this is never received on the nRF52 side. The gatt.writeCharacteristics return OK and i get the onCharacteristicWrite callback. I can however not see anything in the HCI snoop log file.
This is how it should be:
  1. Central -> Peripheral 50 bytes
  2. Peripheral -> Central 43 bytes
  3. Peripheral -> Central 135 bytes
  4. Central -> Peripheral 135 bytes
If (4) is not received within 5 seconds after (3) is sent, the peripheral will disconnect the central. This behavior i can identify. This is the log from the android phone:
05-29 09:40:04.125 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_CONNECT
05-29 09:40:04.126 2369-20902/test_ble_io D/BluetoothGatt: connect() - device: F6:C5:9D:24:12:0A, auto: false
05-29 09:40:04.126 2369-20902/test_ble_io D/BluetoothGatt: registerApp()
05-29 09:40:04.126 2369-20902/test_ble_io D/BluetoothGatt: registerApp() - UUID=24c021fc-7537-4867-8af3-2d6a45c3c7ac
05-29 09:40:04.127 2369-2380/test_ble_io D/BluetoothGatt: onClientRegistered() - status=0 clientIf=6
05-29 09:40:04.576 2369-2381/test_ble_io D/BluetoothGatt: onClientConnectionState() - status=0 clientIf=6 device=F6:C5:9D:24:12:0A
05-29 09:40:04.576 2369-2381/test_ble_io I/BleClientChannel: onConnectionStateChange, status 0, newState 2
05-29 09:40:04.576 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_NEGOTIATE_MTU
05-29 09:40:04.576 2369-20902/test_ble_io D/BluetoothGatt: configureMTU() - device: F6:C5:9D:24:12:0A mtu: 247
05-29 09:40:04.823 2369-2416/test_ble_io D/BluetoothGatt: onConfigureMTU() - Device=F6:C5:9D:24:12:0A mtu=247 status=0
05-29 09:40:04.823 2369-2416/test_ble_io I/BleClientChannel: onMtuChanged, status: 0, mtu: 247
05-29 09:40:04.823 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_DISCOVER_SERVICES
05-29 09:40:04.823 2369-20902/test_ble_io D/BluetoothGatt: discoverServices() - device: F6:C5:9D:24:12:0A
05-29 09:40:04.827 2369-2380/test_ble_io D/BluetoothGatt: onSearchComplete() = Device=F6:C5:9D:24:12:0A Status=0
05-29 09:40:04.827 2369-2380/test_ble_io I/onServicesDiscovered: status: 0
05-29 09:40:04.827 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_VERIFY_SERVICES
05-29 09:40:04.827 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_ENABLE_NOTIFICATIONS
05-29 09:40:04.827 2369-20902/test_ble_io D/BluetoothGatt: setCharacteristicNotification() - uuid: 48f058af-2d79-41af-be4f-722dee1ab571 enable: true
05-29 09:40:04.874 2369-2381/test_ble_io I/BleClientChannel: onDescriptorWrite, status: 0
05-29 09:40:04.874 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_NOTIFICATIONS_ENABLED
05-29 09:40:04.874 2369-20902/test_ble_io I/BleClientChannel: Notifications enabled
05-29 09:40:04.886 2369-20901/test_ble_io I/BleClientChannel: Writing
05-29 09:40:04.887 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_SEND_DATA
05-29 09:40:04.888 2369-2416/test_ble_io I/BleClientChannel: onCharacteristicWrite, status: 0
05-29 09:40:04.888 2369-2416/test_ble_io I/BleClientChannel: cha.getValue(): 2e000000401401651820f38dcc297599a50cfbf5a4c6dcae208c50cf7f0e65cbb8c62fb55722adef6d481401701402533141
05-29 09:40:04.889 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_DATA_SENT
05-29 09:40:04.889 2369-20902/test_ble_io I/BleClientChannel: Message sent
05-29 09:40:04.889 2369-20902/test_ble_io I/BleClientChannel: writeEvent == null => false
05-29 09:40:04.889 2369-20901/test_ble_io I/BleClientChannel: write done
05-29 09:40:04.889 2369-20901/test_ble_io I/BleClientChannel: reading
05-29 09:40:04.969 2369-2380/test_ble_io I/BleClientChannel: onCharacteristicChanged
05-29 09:40:04.970 2369-2380/test_ble_io I/BleClientChannel: cha.getValue(): 270000004014016518200fd62d176784478b0394677e240dba4062863dffef848b45c791576419d54c0641
05-29 09:40:04.972 2369-20901/test_ble_io I/BleClientChannel: reading
05-29 09:40:05.023 2369-2381/test_ble_io I/BleClientChannel: onCharacteristicChanged
05-29 09:40:05.023 2369-2381/test_ble_io I/BleClientChannel: cha.getValue(): 8300000040140162187c7fc176a481bcc71a14465b914f364cca6ae5d3102ba11326a7a98d0a5a7d145e0877a0efc978c64a39a1b86233bbdf2a38b774d212a2d256d0bce900f3755dfdfbd40ea594353897502590291c99331b228a32b5289383abb6a92dd37be6a35edbaf90f6b62aa766f22e78119327be338ff146846401e5f41dd7afaa41
05-29 09:40:05.027 2369-20901/test_ble_io I/BleClientChannel: Writing
05-29 09:40:05.027 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_SEND_DATA
05-29 09:40:05.028 2369-2416/test_ble_io I/BleClientChannel: onCharacteristicWrite, status: 0
05-29 09:40:05.028 2369-2416/test_ble_io I/BleClientChannel: cha.getValue(): 8300000040140162187c4505ac06dfb264f011e6160c0673abc60f61d8460eecc4bc92075bacdcf93727225a10a0915f0aeaf7e033ff67787d6a6922083b4d67a90fa8141360eb32072eb5010364d27d3b7f2fb85c2a4c9f67a1719879e65f6047cccd192631577bfce264cd1fa0efe44916c1424b018a36329f2541666e686c5917ae62619841
05-29 09:40:05.028 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_DATA_SENT
05-29 09:40:05.028 2369-20902/test_ble_io I/BleClientChannel: Message sent
05-29 09:40:05.029 2369-20902/test_ble_io I/BleClientChannel: writeEvent == null => false
05-29 09:40:05.029 2369-20901/test_ble_io I/BleClientChannel: write done
<--- Disconnected by peripheral here --->
05-29 09:40:10.020 2369-2380/test_ble_io D/BluetoothGatt: onClientConnectionState() - status=19 clientIf=6 device=F6:C5:9D:24:12:0A
05-29 09:40:10.020 2369-2380/test_ble_io I/BleClientChannel: onConnectionStateChange, status 19, newState 0
05-29 09:40:10.020 2369-20902/test_ble_io I/BleClientChannel: handleMessage: MSG_CLOSE
05-29 09:40:10.021 2369-20902/test_ble_io D/BluetoothGatt: cancelOpen() - device: F6:C5:9D:24:12:0A
05-29 09:40:10.021 2369-20902/test_ble_io D/BluetoothGatt: close()
05-29 09:40:10.021 2369-20902/test_ble_io D/BluetoothGatt: unregisterApp() - mClientIf=6
05-29 09:40:10.129 2369-20901/test_ble_io D/BluetoothGatt: cancelOpen() - device: F6:C5:9D:24:12:0A
05-29 09:40:10.130 2369-20901/test_ble_io D/BluetoothGatt: close()
05-29 09:40:10.130 2369-20901/test_ble_io D/BluetoothGatt: unregisterApp() - mClientIf=0
And the corresponding HCI snoop log is attached. When looking at the log file i can't see that the second write from the phone is present. Any suggestions?
