How to read fifo data in TWI?
Hello.
I use nRF52 & mpu9250. I want to use dmp. But now it's not going well.
Now, there is no error,but fifo_count doesn't change after fifo_count became 512. I think fifo_count should reset after finished reading fifo data. DMP is enable. It checks code of reading fifo_stream.
I think the cause is method of loading from fifo register.
I test code below,but it's not going well.
static uint32_t mpu9250_read_fifo_register(uint8_t address, uint8_t reg, uint32_t length, uint8_t * p_data)
	uint32_t err_code;
	err_code = nrf_drv_twi_tx(&m_twi_instance, address, &reg, 1, false);
	if(err_code != NRF_SUCCESS) {
		printf("err_code = %d @read_register_#1\n\r",err_code);
		return err_code;
	if(!waitInt(MPU9250_TWI_TIMEOUT)){// for Check timeout
		printf("Timeout read_reg #1\r\n");
		return NRF_ERROR_TIMEOUT;
	twi_done = false;
	for(unsigned char iii = 0; iii < length; iii++){
		uint8_t * p_tmp;
		err_code = nrf_drv_twi_rx(&m_twi_instance, address, p_tmp, 1);
			printf("err_code = %d @read_register_#2\n\r",err_code);
			return err_code;
				printf("Timeout read_reg #2\r\n");
		p_data[iii] = p_tmp[0];
		twi_done = false;
	return err_code;
unsigned short fifo_count;
int mpu_read_fifo_stream(unsigned short length, unsigned char *data,
    unsigned char *more)
    unsigned char tmp[2];
		//printf("mpu_read_fifo_stream st@rt\r\n");
    if (!st->chip_cfg.dmp_on){
			printf("mpu_read_fifo_stream return -1\r\n");
			return -1;
    if (!st->chip_cfg.sensors){
			printf("mpu_read_fifo_stream return -2\r\n");
      return -2;
		unsigned char tmp1[1];
		unsigned char tmp2[1];
		if (i2c_read(st->hw->addr, st->reg->fifo_count_h, 1, tmp1)){
				printf("mpu_read_fifo_stream return -3\r\n");
        return -3;
		if (i2c_read(st->hw->addr, (st->reg->fifo_count_h)+1, 1, tmp2)){
        return -3;
    fifo_count = (tmp1[0] << 8)| tmp2[0];
		printf("temp %x | %x temp - > fifoCount = %d , length = %d\r\n",tmp1[0],tmp2[0],fifo_count,length);
    if (fifo_count < length) {
		more[0] = 0;
		printf("return 1\r\n");
        return 1;
//fifo count > 512
    if (fifo_count > (st->hw->max_fifo >> 1)) {
        /* FIFO is 50% full, better check overflow bit. */
        if (i2c_read(st->hw->addr, st->reg->int_status, 1, tmp)){
					printf("return -5\r\n");
					return -5;
        if (tmp[0] & BIT_FIFO_OVERFLOW) {
            mpu_reset_fifo();
						printf("return 2\r\n");
            return 2;
// fifo_count > 512
    if (i2c_read_fifo(st->hw->addr, st->reg->fifo_r_w, length, data)){
		printf("return -7\r\n");
        return -7;
	for(unsigned char iii = 0;iii<length;iii++){
		printf("%d:%d\r\n",iii,data[iii]);
		delay_ms(10);
    more[0] = fifo_count / length - 1;
	printf("more = %d\r\n",more[0]);
	delay_ms(10);
    return 0;
Please tell me how to read data from fifo register?
added 2017/06/01
  • Yes, I think so. This is what I mean in pseudocode:
    for(as many bytes as you want to read from fifo buffer)
        // nrf_drv_twi_tx(&m_twi_instance, MPU_ADDRESS, FIFO_REGISTER_VALUE, 1, false);
        // nrf_drv_twi_rx(&m_twi_instance, MPU_ADDRESS, ONE BYTE LONG BUFFER, 1);
    My theory is that you have to do a write transfer to tell the MPU that you want to read one more byte from the FIFO buffer for every byte you want to read.
