Is there a way to get more capacitive touch inputs?
Both the capacitive touch library and the driver (which is better ?) are using the analog inputs. There are only 8 of them , and we need 10 at least buttons.
Is there a way to "cheat" ? I need different buttons where you can also detect when I touch 2 at once.
The docs says you can connect 2 pads for the same analog pin which seems impossible knowing the basics of hardware and capacitance ( how one pin differentiate between to shorted pins?) infocenter.nordicsemi.com/index.jsp
Thanks.
  • Hello Lola
    The idea of connecting the input to two pads is described under the resource usage section here. It states that neighboring pads should not be connected to the same input pin. That way by checking the neighboring buttons, you can tell which way the finger is sliding.
    In theory, I think it might be possible for the sensing circuit to tell two different buttons apart, if the two button do not have the same capacitance. Mind you, I have never tried this myself.
    If their capacitance is far enough apart, and you do not have coupling from one to the other, you might be able to tell one pad from the other by how much the frequency of the relaxation oscillator changes. For example, one pad would change the frequency from f0 to f1, the second pad from f0 to f2. If both were pressed, you would get frequency f3.
    A limitation to this however is that the change in capacitance is dependent on many different things, pad size and shape, size of finger, skin moisture etc. so the capacitance can vary a lot. Sadly I am not sure how realizable it would be.
    Best regards
    Jørn Frøysa
  • Actually I am missing just another button ( I need 9 ) , I am trying to think how can I connect it with one of the 8 AIN or maybe all of them to get another behaviour.
