Testing coded PHY with UART?
I have two nRF52840-pdk's and two laptops. I was thinking to send test strings using the following Basic setup:
       laptop1 - usb1 - pdk1 ....(coded PHY transmission)....pdk2 - usb2 - laptop2
Can I use directly some existing example codes for making this to happen?
I tested the ble_app_uart example in a laptop - usb - pdk....(bt4.2)....android-phone
-setup and it worked well, but I am not sure if it could also apply in my pdk-to-pdk case.
  • FormerMember
    0 FormerMember
    Both UART central and the peripheral examples, ble_app_uart_c and ble_app_uart can be used with the nRF52840-pdk.
    Note: SDK 13.0.0 supports S140 v.5.0.0-2.alpha, while the latest version is S140 v. 5.0.0-3.alpha.
    The main difference between 2.alpha and 3.alpha is that 3.alpha supports advertising/connection initiation on coded phy and 2 Mbps, while 2.alpha supports advertising/connection initiation on 1Mbps and the phy can be changed to coded phy/2Mbps after a connection has been established.
  • Thanks,
    1. This set of actions may be too complicated for me, so I'll probably need wait for a new SDK release. Anyway, thanks for the tips, I will try.
    2. I believe that is exactly what I did.
