Flash Data storage index will not initialized after delete?
Say I have 3 records, then I delete them and collect the garbage. If I try to save a new record again, it will be saved with a record ID 4 , but it should be back to 1 after the delete.
EDIT: The indexes are actually going crazy, if you start your program by erasing memory and then saving a new record after it, and you run this multiple times, your writing record ID for every save would go :
ID=1
ID=3
ID=5
ID=7
instead of staying at 1 all the time , because you delete and collect every run before you save.
delete :
        #define FILE_ID     0x1111
	#define REC_KEY     0x2222
	fds_record_desc_t   record_desc;
	fds_find_token_t    ftok ={0};
	ftok.page=0;
	ftok.p_addr=NULL;
	// Loop and find records with same ID and rec key and mark them as deleted.
	while (fds_record_find(FILE_ID, REC_KEY, &record_desc, &ftok) == FDS_SUCCESS)
		fds_record_delete(&record_desc);
         fds_gc();
I save again only after the handler result :
static void fds_evt_handler(fds_evt_t const * const p_fds_evt) {
 case FDS_EVT_GC:
                 if (p_fds_evt->result == FDS_SUCCESS)
                  { (*flashDelegate)("garbage collected !"); }   // ** this will happen and here i save
case FDS_EVT_DEL_FILE  //this will not happen but it will delete the file
So what happens is that when I save after the delete, he start saving from record ID >1 .
Save with this :
	fds_record_t        record;
	fds_record_chunk_t  record_chunk;
	// Set up data.
	record_chunk.p_data         = &toSave;
	record_chunk.length_words   = (sizeof(toSave)+3)/4;
	// Set up record.
	record.file_id              = FILE_ID;
	record.key              		= REC_KEY;
	record.data.p_chunks       = &record_chunk;
	record.data.num_chunks   = 1;
	ret_code_t ret = fds_record_write(&record_desc, &record);
I even tried to init it before write with this :
  record_desc.record_id = 1 ;
but it's still different from 1 even after the delete and the gc.
