Why the device will connect again when we diconnect from device?
I modified the nordic uart apk from this website
github.com/.../Android-nRF-UART
and I do some revising below
MainActivity.java:
if (action.equals(WearableService.ACTION_GATT_DISCONNECTED)) {
    runOnUiThread(new Runnable() {
     public void run() {
     Log.d(tAg, "UART_DISCONNECT_MSG");
     mState = UART_PROFILE_DISCONNECTED;
     //mService.close(); <--- I comment this
When I disconnect from device, I can see log on my phone Xperia X compact (android 7.0)
BluetoothGatt: cancelOpen() - device: F1:C1:E2:24:ED:57
BluetoothGatt: onClientConnectionState() - status=0 clientIf=5 device=F1:C1:E2:24:ED:57
BluetoothGatt: discoverServices() - device: F1:C1:E2:24:ED:57
BluetoothGatt: onSearchComplete() = Device=F1:C1:E2:24:ED:57 Status=0
BluetoothGatt: setCharacteristicNotification() - uuid: 6e400003-b5a3-f393-e0a9-e50e24dcca9e enable: true
I find It will connect again after I disconnect from the device and then do discoverServi
ce and finally disconnect, why???? The workaround method is uncomment the mService.close() to release the resource when MainActivity.java gets DISCONNECT broadcast.
Below is the screen shot of my phone(we only revised UUID for UartService, there are no revising at Uart apk). When I disconnect from device at 10:18:45 and then reconnect at 10:18:47 and then send one command(this device automatically notify data to apk per 3 second) and then finally disconnect.image description
Another product we develop is below, because it will reconnect, so the button still show Disconnect, not Connect, and we can't change button state anymore, because it has disconnect, we can't send disconnect command to it.image description
below is operate null pointer.image description
