APP_UART_COMMUNICATION_ERROR
Hello, I have problem when trying to use non default pins for uart.
This is what i got:
UART:WARNING:Function: nrf_drv_uart_init, error code: NRF_SUCCESS.
UART:INFO:Transfer rx_len: 1.
UART:INFO:Function: nrf_drv_uart_rx_for_uarte, error code: NRF_SUCCESS.
line: 88, error_code: 4, file: ../../../uart/uart.c
APP_ERROR:ERROR:Fatal
uart/uart.c
96     case APP_UART_COMMUNICATION_ERROR:
97       APP_ERROR_HANDLER(p_event->data.error_communication);
98       break;
When i use default pins for uart_init i don't have this error. If after that i make uart_init with my pins it works for some time.
I have nrf52 with sdk12 or sdk13.
Any help would be appreciated.
  • FormerMember
    0 FormerMember
    When I test here using the UART example with loopback-test, and simulating a disconnect by removing the wires making the loopback, I see that there is a problem when logging over RTT is enabled. However, if the log module is disabled, the example works as expected: upon a APP_UART_COMMUNICATION_ERROR, there is a system reset, and the UART communications works normally again when the loopback is connected.
  • FormerMember
    0 FormerMember
