NRF52 - Extract correctly IRK from connected_evt
I'm working with SDK 11 on nRF52832.
I want to get the IRK from a connection event. I need to identify the connected device.
My following code :
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED: {
            app_timer_start(m_debug_timer_id, DEBUG_TIMER_INTERVAL, NULL);
            ble_gap_addr_t  addr;
        	  pm_peer_data_flash_t compared_data;
        	  if( im_address_resolve(&p_ble_evt->evt.gap_evt.params.connected.peer_addr,
                                                   &compared_data.p_bonding_data->peer_id.id_info) == true) {
              // match
          	} else  {
        		// no matching
            // No implementation needed.
When I check : &compared_data.p_bonding_data->peer_id.id_infoI can read an IRK but it's always the same even if I change the smartphone.
I have something like that :
  • Addr_type = 2
  • Addr = xx:xx:xx:xx:xx:xx
  • IRK = xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
How can I get the correct IRK for the connected device. On a connection_evt I want to extract the IRK and the resolvable adress to manually check if they match.
I' have tried to connect with nRF connect and also bonding.
Thank you in advance.
