Getting deep into capacitive touch driver
Hi. I am investigating the cap touch for a while, and I am working directly with the capacitive driver from here.
As being said there and other places, the driver will NOT use the COMP, but the ADC to measure, and while I take measurments I have 2 problems :
  1. To measure, as described, there is a resistor(1M) going from digital out to analog in, and the pad sensor goes to analog in. They show in the example that you can connect multiple sensors using this 1 output, but how would you connect 1 digital out, to multiple analog ins? you are going to short all your pads in any configuration you choose ( because pads goes to AINs and the single out goes to ALL inputs after the resistor)
  2. when measuring, they say that when I touch i have to measure higher results , but look what happens when I touch :
:INFO:2 1372  //no touch
:INFO:2 1631
:INFO:2 1386
:INFO:2 1798
:INFO:2 1102
:INFO:2 1798
:INFO:2 989   // *touched from here !
:INFO:2 1775
:INFO:2 669
:INFO:2 1689
:INFO:2 667
:INFO:2 1699
:INFO:2 759
:INFO:2 1666
:INFO:2 717  // still touching
you can see that when i touch there is some sort of square signal and it's not just goes down (or up as it supposed to do ) . I can get over this easily buy it seems wrong.
