I would like to have a PDF version of the SDK 13 documentation so I can search and not get results for SDK 9.
There is only off-line DOC archive (HTML) available at the same download site as the SDK itself (this is for every major SDK release and it's pretty much equivalent of PDF I think).
Actually not equivalent.
I want to see only the things that are relevant for SDK 13, not every SDK which has preceded it.
I have that copy, but getting to see one HTML page at a time makes using ti difficult.
Yes indeed, HTML archive isn't PDF but the documentation I've linked IS ONLY FOR SDK V13. What do you mean you want only for V13 and not for every SDK? If you want to see DIFF then simply two SDK versions and compare it in Kdiff3. I'm not sure how PDF makes it easier, your screen size won't change, you will need to crawl the document anyway and when it comes to search HTML archive has it embedded (including pre-generated index so it gives you hints as you type, you hardly beat it with PDF in Acrobat reader...)
This is not an attempt to answer the question.
@daguro: I am afraid that we do not create PDF versions of the documentation, we only provide the off-line doc archive, as pointed out by endnode.
