SoftReset on sd_power_system_off();
For some reason I get a softreset instead of a sleepmode when I call sd_power_system_off();
Device: NRF52832
SDK: 12.2
S132 v 3.0
I do clear all gpiote interrupts before the sleep: nrf_gpiote_event_clear(NRF_GPIOTE_EVENTS_PORT);
Im not in debug mode.
Any idea what could be the reason for this?
Thanks!
  • FormerMember
    0 FormerMember
    Could you double check if there is not anything triggering a wake-up immediately after entering system off?
  • I disabled gpio interrupts, I never use adc, so not sure what else could wake it up?
  • FormerMember
    0 FormerMember
    To get to know exactly what is going on, you can disable the softdevice (sd_softdevice_disable() ) before entering system off. Then the chip can enter system off by setting then SYSTEMOFF register directly. Could you check if doing so change anything?
  • Found a problem...I used nrf_drv_gpiote_in_init()...and had to do nrf_drv_gpiote_in_uninit() before going to sleep. But was expecting this to be fixed with nrf_gpiote_event_clear(NRF_GPIOTE_EVENTS_PORT);
