twi busy error 17
Hello guys, i randomly get twi error busy 17.
i have #define TWI_DEFAULT_CONFIG_IRQ_PRIORITY 7 in sdk_config.h and .interrupt_priority = APP_IRQ_PRIORITY_LOW in init function.
This is my code:
void twi_init(void)
  if(twi_init_status) return;
  ret_code_t err_code;
  const nrf_drv_twi_config_t twi_mma_7660_config = {
    .scl                = SCL,
    .sda                = SDA,
    .frequency          = NRF_TWI_FREQ_100K,
  err_code = nrf_drv_twi_init(&twi_instance, &twi_mma_7660_config, twi_handler, NULL);
  nrf_drv_twi_enable(&twi_instance);
  nrf_delay_ms(200);
  twi_init_status = true;
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
  switch(p_event->type)
    case NRF_DRV_TWI_EVT_DONE:
      m_xfer_done = true;
and this are my read and write functions:
void twi_write(uint8_t dev_addres, uint8_t reg_addres, uint8_t data[], uint8_t length)
  uint8_t buffer[length];
  buffer[0] = reg_addres;
  for(int i = 0; i < length; i++) buffer[i+1] = data[i];
  m_xfer_done = false;
  ret_code_t err_code = nrf_drv_twi_tx(&twi_instance, dev_addres, buffer, sizeof(buffer) + 1, false);
  while (!m_xfer_done);
void twi_write_no_register(uint8_t dev_addres, uint8_t data[], uint8_t length)
  ret_code_t err_code = nrf_drv_twi_tx(&twi_instance, dev_addres, data, length, false);
void twi_read(uint8_t dev_addres, uint8_t reg_addres, uint8_t *data_pointer, uint8_t length)
  err_code = nrf_drv_twi_tx(&twi_instance, dev_addres, buffer, 1, false); // sends ADDR+W, dev_addres, reg_addres
  err_code = nrf_drv_twi_rx(&twi_instance, dev_addres, buffer, length); // reads from reg_addres #(length) of bytes
  for(int i=0;i<length;i++)
    *data_pointer=buffer[i];
    data_pointer++;
I was reading posts about this problem but coudn't find a solution. I tried to put delays after twi functions but it didn't resolve the issue. Is this something i should handle in my code (if yes how would be helpfull)? I have also tried blocking mode and the error is the same. Sometimes it works for hours and sometime error occures right away.
Thanks.
