I am able to program my custom board using nrf52dk (only 32 Mhz osc populated on custom board), and I can also see the output of SEGGER_RTT_WriteString() though JLinkRTTClient command. But I am getting hardfaults when I have uart in use.
I have set the source for LFCLK to be internal RC oscillator. I know internal rc osc is not the best option when uart needs to be used, but would it cause a hardfault ? What could be the possible reasons for hardfault ? Backtrace is not giving much information:
#0 0x0001e054 in ?? ()
#1 <signal handler called>
#2 0x00000000 in ?? ()
#3 0x00020256 in uart_event_handler (p_event=0x8e5, p_context=0x20000400) at ../components/libraries/uart/app_uart.c:49 Backtrace stopped: previous frame inner to this frame (corrupt stack?)
The above happens after four loops which try to run app_uart_put() (see code below).
Code:
void bsp_configuration()
uint32_t err_code = NRF_SUCCESS;
NRF_CLOCK->LFCLKSRC = (CLOCK_LFCLKSRC_SRC_RC << CLOCK_LFCLKSRC_SRC_Pos);
NRF_CLOCK->TASKS_LFCLKSTART = 1;
while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0) {
// Do nothing.
APP_TIMER_INIT(APP_TIMER_PRESCALER, /*APP_TIMER_MAX_TIMERS,*/ APP_TIMER_OP_QUEUE_SIZE, NULL);
err_code = bsp_init(BSP_INIT_LED, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), NULL);
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info) {
SEGGER_RTT_printf(0,"Error (id,pc,info): %x,%x,%x\n");
void gpiote_init() {
if (!nrf_drv_gpiote_is_init())
nrf_drv_gpiote_init();
uint32_t err;
nrf_drv_gpiote_out_config_t led_config = GPIOTE_CONFIG_OUT_SIMPLE(true);
err = nrf_drv_gpiote_out_init(18, &led_config);
APP_ERROR_CHECK(err);
/**@brief Function for application main entry. Does not return. */
// Setup bsp module.
bsp_configuration();
uart_init();
gpiote_init();
uint32_t err;
uint8_t byte;
err = NRF_LOG_INIT(NULL);
SEGGER_RTT_Init();
nrf_delay_ms(DELAY_MS);
for (;;) {
SEGGER_RTT_WriteString(0,"Toggling led 18\n");
nrf_drv_gpiote_out_toggle(18);
nrf_delay_ms(500);
app_uart_put('*');
Output I get from JLinkRTTClient:
Error (id,pc,info): 2000FF2C,2000FF2C,1440000
Toggling led 18
Toggling led 18
I do not get hardfaults if I comment out app_uart_put().
