INVALID_PARAM for sd_ble_gatts_rw_authorize_reply
I've recently hit an issue where sd_ble_gatts_rw_authorize_reply in my code returns INVALID_PARAM when I try and write a long set of data to a characteristic using the NRF Connect app. Shorter data works perfectly.
It's using totally standard code from Nordic's examples:
  case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
      ble_gatts_evt_rw_authorize_request_t  req;
      ble_gatts_rw_authorize_reply_params_t auth_reply;
      req = p_ble_evt->evt.gatts_evt.params.authorize_request;
      if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
          if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
              (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
              (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
              if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                  auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                  auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
              auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
              err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                         &auth_reply);
  } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
edit: Simply download the Nordic UART example firmware and follow the steps below. It has exactly the same problem
It's using one service - the standard Nordic UART using Nordic's NUS library, but I'm doing that with Espruino. It's trivial to reproduce - simply download the nrf52832dk hex file from www.espruino.com/.../, connect with nRF Connect on Android, and then go to the NUS RX characteristic and send one really big packet - it reboots with an error.
(You can see the error better if you connect via the USB UART at 9600 baud first and send Serial1.setConsole(1), then connect with nRF Connect, then send the big packet)
Any ideas what I might be doing wrong? I'm using s132_nrf52_3.0.0_softdevice.hex (SDK 12.1) at the moment. I know that's not the current one but it'll be a pain to change.
If I create a second service and characteristic and write a lot of data into that I get exactly the same problem as well.
thanks!
