esb RX can't change PID of payloads sent to TX
In a project using esb, with two nrf52832 devices configured as default, one as RX, one as TX, with dynamic payload, TX sending packets to RX can change the packet pid (and using a debugger I can see that the pid changes on every subsequent packet provided I have a command such as tx_payload.pid++ on every send). However this doesn't work for RX; even with the above command, packets I receive with TX from RX always have pid == 0. Is this intended behaviour? Should I not be changing pid in the TX program?
In the meantime I've switched to using the first byte of each packet to store a packet identifier, which lets TX request a packet from RX that it hasn't obtained during a transfer, but if I could do the same with the pid that would make things cleaner, and give me an extra byte to store things in.
  • Hello Adrien Rapeaux
    The PID of the packets is only changed on the TX side. The RX ACK PID should be the same as the TX PID used in the message it is answering. This is meant to help the TX confirm that the payload it received is in fact an answer to its previous message. Take a look at the packet format descriptions and transaction diagrams of the nRF24L01P product specification, sections 7.3 and 7.4 pages 28 and 45.
    What happens if you do not try to change the value of the ACK PID? Does it then mirror the PID from the transmitter?
    Best regards
    Jørn Frøysa
  • I have spoken to a colleague and it turns out the TX side does not load the PID value from the payload buffer. If you go to nrf_esb.c, line 627 you will find the line
    if (rx_fifo_push_rfbuf((uint8_t)NRF_RADIO->TXADDRESS, 0))
    Try changing this to
    if (rx_fifo_push_rfbuf((uint8_t)NRF_RADIO->TXADDRESS, m_rx_payload_buffer[1]>>1))
    That should make the pid available in the rx_payload.pid in main.
