Undesirable reset of nrf51822
Hello, I am using PCA10028 and sdk12.2. My challenge is nrf51822 resets after it executes the code for the first time.
I am storing few values in flash. After that I am using function for advertising. But after advertising for few seconds my nrf51 resets. I am attaching my code with New Text Document (2).txt
Please let me know suggestions.
Thanks, Shailav
    A reset indicates that you are running into the error handler, where the default behavior is to do a reset. You should then debug in order to find the reason for the reset. See this post about debugging.
    Doing a quick test with the code you posted, I got the error FDS_ERR_NO_SPACE_IN_QUEUESfrom the fds_test_write() in the main() function.
    From infocenter:
    FDS_OP_QUEUE_SIZE: The size of the internal queue of FDS operations. Increase the size if there are many users, or if your application will queue many operations at a time without waiting for the previous operations to complete. In general, you should increase the queue size if you frequently receive FDS_ERR_NO_SPACE_IN_QUEUES errors.
    FDS_CHUNK_QUEUE_SIZE: The number of record chunks (pieces of record data) that can be buffered. Increase the queue size if you frequently receive FDS_ERR_NO_SPACE_IN_QUEUES errors and your data is typically composed of many chunks.
  • Hello Sigurd, I want to store 4000 samples in flash and send it out to nrf app using ble. I have tested the return value of FDS_TEST_INIT, FDS_TEST_WRITE and FDS_TEST_READ and all returns 0 and I think this means success. Can you edit the code or suggest me what should I add to get rid of this error. Thanks, Shailav
  • Yes, 0 means success, so then you could be getting a different error. Please debug to find the error.
    You also have a duplicate in Mypage and here. Please continue on MyPage. Closing this one as duplicate.
