why am i running out of heap memory when i am freeing my linked list?
i am creating a user interface using the sh1106 driver for a 128x64 pixel oled screen. so every screen is a list of items to be scrolled; however almost every screen i am using a linked list for the list of elements. in one screen i am creating a linked list and freeing it for about 12 to 15 times but when i reach a number like that the malloc is returning NULL so that means the malloc is not able to find the memory space i need. but what could be the cause? could it be a memory leak from the way i am freeing the linked list? could it be that the memory free space has become too fragmented? if so why only this linked list is messing up?
thanks in advance for ur help guys! and if there is anything needs clearing up or u need some extra info let me now and ill post it.
the code is below: (please keep in mind that i am extracting information from database saved in flash)
void createNotesListFromDb(linkedListNotes_t **head){
notes_t notesStructure;
uint8_t tuningID = dbGetTuningID(instrumentRefID);
tuningRefID = tuningID;
tuningNotesCount = dbGetTuningNotesCount(tuningID);
nbrOfNoteNodes = 0;
char notesTransferArray[4];
for(uint8_t nmbr = 1;nmbr <= tuningNotesCount; nmbr++)
	notesStructure = dbGetNote(tuningID, nmbr);
	// the next part is to fill a new node with desired values and information
	linkedListNotes_t * newNoteNode;
	newNoteNode = (linkedListNotes_t*)malloc(sizeof(linkedListNotes_t));
	newNoteNode->index = notesStructure.index;
	newNoteNode->alteration = notesStructure.alteration;
	newNoteNode->octave = notesStructure.octave;
	newNoteNode->cents = notesStructure.cents;
	generateNoteName(notesTransferArray, notesStructure.index, notesStructure.alteration, notesStructure.octave);
	newNoteNode->name = (char*)malloc(strlen(notesTransferArray)+1);
	strcpy(newNoteNode->name, notesTransferArray);
	newNoteNode->next = NULL;
	*head = addNotesNodeToTail(*head, newNoteNode);
	nbrOfNoteNodes++;
void freeNotesList(linkedListNotes_t * head){
linkedListNotes_t * tmp = NULL;
while (head != NULL)
	tmp = head;
	head = head->next;
	tmp->next = NULL;
	free(tmp->name);
	tmp->name = NULL;
	free(tmp);
	tmp=NULL;
linkedListNotes_t * addNotesNodeToTail(linkedListNotes_t *head, linkedListNotes_t * newNode){
linkedListNotes_t * temp;
if (!head)
    head = newNode;
    return head;
temp = head;
while (temp->next)
    temp = temp->next;
temp->next = newNode;
return head;
Parents Reply
  • Memory fragmentation is the most likely reason, yes. The problem is that you are continuously allocating and de-allocating small blocks of varying size, and since there is no way to 'defragment' the memory it will eventually get so fragmented that there are no free blocks large enough for your buffers.
    You would be better of with a static table of nodes, with a defined maximum length for your name string. The average memory consumption would be larger, but you would not have any issues with fragmentation.
