About RSSI of BLE
Hi, I am trying to get the rssi value of a connection, and what I am trying to do is to start the rssi in the beginning at the connection and end it at the end of connection. So in my on_ble_evt of my app I have:
    case BLE_GAP_EVT_CONNECTED:
        nrf_gpio_pin_set(CONNECTED_LED_PIN_NO);
        nrf_gpio_pin_clear(ADVERTISING_LED_PIN_NO);
        err_code = sd_ble_gap_rssi_start(m_conn_handle);
        err_code = sd_ble_gap_rssi_stop(m_conn_handle);
        nrf_gpio_pin_clear(CONNECTED_LED_PIN_NO);
The problem is that the sd_ble_gap_rssi_stop function is not working properly. I am guessing the connection ended before this so causing the rssi_stop cannot work. Do you have any idea how can I walk around it?
    We have recently come across this bug, where the RSSI stop function does give back an error code. The connection handle is actually invalid once the "BLE_GAP_EVT_DISCONNECTED" is called, so this is why you are seeing an assert at this point. The bug from Nordic's side is that the RSSI is not stopped properly after a disconnect occurs.
    You can work around this by: call function "(void)sd_ble_gap_rssi_stop(m_conn_handle);" before starting RSSI in BLE_GAP_EVT_CONNECTED.
    Another way is to use a variable to stop the RSSI, as the attached .c file shows.
    You should then not call sd_ble_gap_rssi_stop in the "BLE_GAP_EVT_DISCONNECTED" event.
    Best regards Håkon
    sd_rssi_wrkaround.c
  • This issue was fixed in version 6.0.0 of the S110 SoftDevice.
    Here's a quote from the release notes: Fixed an issue where calling sd_ble_gap_rssi_stop() after connection had ended would cause an assert. In addition, RSSI will now be stopped automatically when the connection ends (NRFFOETT-499, DRGN-3131).
