Eclipse compiled hex file smaller than included hex
I've managed to overcome all the quirks in setting up Eclipse/gcc development with the nRF52 PDK (PCA10056), and I can build the sample projects just fine. Here's my issue: If I compile and load the "blinky" example project, it runs perfectly. If I try to do the same with ble_app_uart, it compiles just fine, but when I load the resulting hex file, it doesn't work--the nRF Connect app can't see it, there's no blinking LED on the PDK, etc.
I also noticed that the .hex file that results from the build is only 84kB, whereas the pre-compiled .hex in the SDK is 421kB. I suspect there's something wrong with the build, so when it loaded onto the chip, it doesn't run correctly, but I have no idea where to start looking for issues--there are no problems in the build process.
I programmed the s140 SoftDevice to the target earlier, and have verified (using nRFGo Studio) that it's still there.
Where should I look in order to figure out what I'm doing wrong?
    First of all the HEX files supplied with SDK are already merged with Soft Device (where applicable), you can easily verify that by comparing content with any tool like Kdiff3. Then even if you strip SD part and compare just "APP" you will most probably arrive to different content and size because Nordic compile by default with Keil or IAR and you are using GCC. But that should not be a big problem (and if you like to start with 100% binary compatible output - as I do - you will need to use different compilation chain - which I don't like as well, GCC is great).
    The fact that your FW is not working is probably caused by some linking/include error, e.g. not setting RAM and FLASH boundaries properly in LD script or so. If you show us more from GCC output when you build the thing we might give you more hints.
    Cheers Jan
  • It looks like using nRFgo Studio to program the application worked. The drag-and-drop method must erase the entire flash when loading the new code.
