Hi
I use LESC sdk & nrf connect app
How can I know if my nrf51 device and phone are bounding through LESC?
From nrf connect( ios ), how can I know from nrf connect(ios) that the nrf51 device is bounded?
Thanks.
Hi
Thanks.
Hi Johnny,
You can check the sniffer trace to see what happened over the air.
If you don't want to use the sniffer, you can check the BLE_GAP_EVT_AUTH_STATUS event and check which security level you end up. If it's LESC and MITM, you will have security mode 1 and level 4. Check p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4 if it's =1 .
If it's Just work you used, you will end up with security mode 1 and level 2 which is the same level as Legacy Pairing Just Work.
I believe the iOS nRFConnect app will show you if the device is bonded in the app. It say "Not bonded" or "Bonded"
