My 32Mhz crystal isn't working on Nrf52840?
Hello, I connected, according to official layout design, a 32 Mhz crystal to my nrf52840. Using a 60 Mhz oscilliscope, I decided that the crystal isn't working (no sine wave form no matter what) and I think it has something to do with the fact that I haven't properly configured relevant registers to enable it.
So... what are the list of registers that I should mind and configure to get the xtal to work?
The nrf52840 OPS v0.5, as usual, gives very, very brief and general information therefore not so helpful.
  • Are you using a SoftDevice? Have you tried any of the examples and checked if the radio is working? Also please state what oscilloscope you're using for your measurements.
  • You are not able to see sine waveform if sampling frequency is not greater than 2 x measured frequency. Please read about Nyquist rate.
    Your sampling frequency = 60MHz - best case if only one osciloscope channel is active.
    Measured frequency = 32MHz.
  • You might try an active high-z probe as the Normal probes typically load the drive circuitry down.
    Yes I am. And I can't seem to remember where I have configured the SD to my clock frequency. I don;t think it's necessarily though, because I'm using the by default required 32Mhz xtal?
    No. I haven't, I want to see if I can get things right on the first go.
    tektronix tds1002, 60Mhz dual channel. 60Mhz may be a problem as the sampling frequency is too low.
    Anyway, can you tell me what are the registers that I have to properly configure to get the chip running properlly?
  • Still, what are the registers I have to mind if I want to get everything up and running properly?
