I'm trying to store some values with fstorage. The store operations seem to be queued successfully, but never executed. I currently have this to test the behavior:
FS_REGISTER_CFG(fs_config_t fs_config) =
.callback = fs_evt_handler, // Function for event callbacks.
.num_pages = 1, // Number of physical flash pages required.
.priority = 0xFE // Priority for flash usage.
static void fs_evt_handler(fs_evt_t const * const evt, fs_ret_t result)
nrf_drv_gpiote_out_toggle(LED_PIN_3);
if (result != FS_SUCCESS)
APP_ERROR_HANDLER(result);
fs_ret_t ret = fs_init();
if (ret != FS_SUCCESS)
APP_ERROR_HANDLER(ret);
const uint32_t * storage_loc = fs_config.p_start_addr;
fs_ret_t ret;
ret = fs_erase(&fs_config, storage_loc, 1, NULL);
nrf_drv_gpiote_out_toggle(LED_PIN_1);
ret = fs_store(&fs_config, storage_loc, (uint32_t *)data, 1, NULL);
nrf_drv_gpiote_out_toggle(LED_PIN_2);
Both fs_erase and fs_store return FS_SUCCESS, but the fs_evt_handler is never called.
Original question: I have an application that records sensor measurements as soon as a characteristic is set via BLE. I'm using fstorage to save these values. I noticed that the fstorage queue runs full when I stay connected via BLE after setting the characteristic. I tried fiddling with the FS_QUEUE_SIZE and FS_MAX_WRITE_SIZE_WORDS parameters, but the problem persists. I don't want to assume that the user of the device disconnects after any given period, so my question is: is there a way to support writes while BLE is connected? (Maybe fiddling with the BLE connection parameters?)
