Hi I have some questions regardning the crystals needed for the NRF51822 chip.
I know that I can remove the 32kHz external clock and use the internal clock. But can I use the internal 16MHz clock instead of the external? My app does not require any well defined time base, but does the SD need a accurate 16MHz source?
If I can not remove the external crystal, can I use a external resonator? What is the minimum frequency tolerance for the 16MHz source?
Thanks for your good service!
