SPI MOSI default high? NRF SDK 12.2.0
I am attempting to interface a Winbond flash device with the NRF52. The datasheet does not specify the idle state of MOSI when reading from the device. However, I cannot make the flash chip work with the NRF52. In the attached image, an Arduino successfully sends a command to the devices (0x06H) then reads a register (0x05H) and gets the expected result (0x02H).
Arduino
As you can see here, a NRF52 sending the same sequence of commands (roughly speaking) does not get a response. I've tried a number of different frequencies and both mode 0 and 3, which are the two modes the flash chip supports.
NRF52 on BMD-300 eval
The one obvious difference between the Arduino's output and the NRF52's output is the state of MOSI in between transfers. Although the flash memory specifies a D/C during idle periods I would like to try setting MOSI high during idle periods.
Is there a way to do this?
