Can anybody tell what is the max transmit range of nrf52810 in meters? and how many devices can meshed with the same?
nRF52832 or nRF52810? It actually should be the same and in the end beside sensitivity all the radio properties are not telling anything without particular antenna and tuning so what do you expect from the answer? Yes, it can do 1km on free air, maybe more, maybe much less, will be different board per board.
Hi Pavan
Range is very hard to predict, since it will change a lot depending on the environment, hardware design, and radio configuration.
Line of sight range is typically several hundred meters, while in door range is much smaller (20-30m typically).
How many devices you can have in a mesh network depends mostly on the mesh protocol used. Technically speaking it is possible to have hundreds of nodes within close proximity, and a total network size of several thousand nodes.
Best regards
Torbjørn
As already noted, range is affected by far more than just the chip itself.
Google "Link Budget" - this is what determines range in any radio system.
