HI, i m beginner in TWI with nrf52832. i want to write a bit in a registre of hmc5883l but i didnt succeed. what i want to do is :
writeByte(devAddr, regAddr, b) ==> ( 0x1E,0x37,1)
tgis my own code that i tried but i didn't understand why is not working! help if u can
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
/* Number of possible TWI addresses. */
#define TWI_ADDRESSES 127
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
* @brief TWI initialization.
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
nrf_drv_twi_enable(&m_twi);
bool writeBit()
uint8_t packet[1] = {0x37};
err_code = nrf_drv_twi_tx(&m_twi,(0x1E),packet,sizeof(packet),false);
return err_code;
uint8_t address;
uint8_t sample_data;
uint8_t data;
bool detected_device = false;
NRF_LOG_INFO("TWI scanner.\r\n");
NRF_LOG_FLUSH();
twi_init();
if(writeBit()==true)
NRF_LOG_INFO("No hmc5883l device was found.\r\n");
NRF_LOG_FLUSH();
for (address = 1; address <= TWI_ADDRESSES; address++)
err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
if (err_code == NRF_SUCCESS)
detected_device = true;
NRF_LOG_INFO("TWI device detected at address 0x%x.\r\n", address);
NRF_LOG_FLUSH();
if (!detected_device)
NRF_LOG_INFO("No device was found.\r\n");
NRF_LOG_FLUSH();
while (true)
/* Empty loop. */
Anyway, I think I may have misunderstood you. Is it so that you have three slave devices, one MPU6050, one BME280, and one HMC5883L? But only the first two are responding? How have you connected everything? Why do you need to enable the I2C bypass features in the MPU6050?
