twi, mpu650 + hmc5883l
HI, i m beginner in TWI with nrf52832. i want to write a bit in a registre of hmc5883l but i didnt succeed. what i want to do is :
writeByte(devAddr, regAddr, b) ==> ( 0x1E,0x37,1)
tgis my own code that i tried but i didn't understand why is not working! help if u can
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0
 /* Number of possible TWI addresses. */
 #define TWI_ADDRESSES      127
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
 * @brief TWI initialization.
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    nrf_drv_twi_enable(&m_twi);
bool writeBit()
		uint8_t packet[1] = {0x37};
		err_code = nrf_drv_twi_tx(&m_twi,(0x1E),packet,sizeof(packet),false);
   return err_code;
    uint8_t address;
    uint8_t sample_data;
		uint8_t data;
    bool detected_device = false;
    NRF_LOG_INFO("TWI scanner.\r\n");
    NRF_LOG_FLUSH();
    twi_init();
	if(writeBit()==true)
				NRF_LOG_INFO("No hmc5883l device was found.\r\n");
        NRF_LOG_FLUSH();
    for (address = 1; address <= TWI_ADDRESSES; address++)
        err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
        if (err_code == NRF_SUCCESS)
            detected_device = true;
            NRF_LOG_INFO("TWI device detected at address 0x%x.\r\n", address);
        NRF_LOG_FLUSH();
    if (!detected_device)
        NRF_LOG_INFO("No device was found.\r\n");
        NRF_LOG_FLUSH();
    while (true)
        /* Empty loop. */
  • The three chip are included in the same card, we use gyro 87 and the mpu6050 is actived by default but the HMC5883L need the bypass active to get the communication with it. The problem is resolved and now I get communication with all chips, we get library for NRF51 that simplify the communication TWI so we have updated it to NRF52 and we use it, one library for both MPU6050 and HMC5883L.
