printf() in Keil over Debug / ITM / UART / RTT, nothing works
I've been trying to for two days. Using nrf52DK, SDK12, no SD, Keil5.
All I want is to get printf() to work over ITM/SW/Debug, I'd even accept RTT if I had to. I can't seem to get anything to work.
Tried to import the retarget.c and app_uart into my simple program, that was a dependency disaster.
I've followed every guide I can find here, every post that mentioned retarget. Keil docs, Nordic docs, etc. Nothing seems to work.
  • Has anyone got printf() over Debug/ITM working!?
  • How can this be so difficult when it's between click and go on STM32 or maybe a couple extra lines of code at the worst?
  • Is there some reason nrf52832 can't use a virtual comm port?
  • I'm also having issues with RTT, so is there an SDK12 guide for that?
  • Using the UART EXAMPLE from SDK12, I get a total failure. Using the loopback test, at the line: if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS)) I'm getting an err_code of 0x05 (not found?) totally unmodified code.
Any help would be appreciated.
  • @SRA, I just updated my response to make it clearer with the comment that followed. I gave some generic function as it depends on what you plan to use to output (in my case, its a software based uart as I need the hardware uart for other things!). When I'm back in the office I'll make a quick example that outputs printf to both the uart and the RTT. In the meantime, can you confirm that when you call "app_uart_put" it outputs a character?
