How to achieve the transmission distance of 100m with nRF52810 ?
By designing proper HW with properly tuned antenna.
Also, make sure to use +4dBm output power and 1Mbps on air bitrate for the optimal range.
It is impossible to guarantee 100m range in all cases, even with a good hardware design and the right radio parameters. If you have line of sight it shouldn't be a problem, but indoor you will some times have issues because of thick walls, extensive interference (from WiFi for instance), and so forth.
Best regards
