[SDK 13] [UART_APP_FIFO] Problem with FIFO flush.
Hello.
I notice a problem with app_uart_flush function, which is calling app_fifo_flush function and in this we have a:
uint32_t app_fifo_flush(app_fifo_t * p_fifo)
    p_fifo->read_pos = p_fifo->write_pos;
    return NRF_SUCCESS;
With that when I check m_tx_fifo and m_rx_fifo in app_uart_fifo.c file after some time before block I got a next values:
image description
How it's possible when in app_fifo_put function we have a macro to check fifo length ?
uint32_t app_fifo_put(app_fifo_t * p_fifo, uint8_t byte)
    if (FIFO_LENGTH() <= p_fifo->buf_size_mask)
        fifo_put(p_fifo, byte);
        return NRF_SUCCESS;
    return NRF_ERROR_NO_MEM;
After some changes in app_fifo_flush:
    p_fifo->read_pos = 0;
    p_fifo->write_pos = 0;
    return NRF_SUCCESS;
UART seem work properly.
It's correct solution, or I should do this on another way ?
BR, Kamil
    What is the problem with the values you have in m_tx_fifo and m_rx_fifo?
    In both cases the FIFO_LENGTH() is 0 (the difference between read and write position), and you will not get NRF_ERROR_NO_MEM based on the picture you posted.
    You should not change the app_fifo_flush() function.
    It should look like this:
        return NRF_SUCCESS;
