How to set two interrupts for one pin?
On nRF52 interrupts for GPIOTE, I need to perform one event when a button is pushed, and perform another different event when the button is released.
I've checked these links already, buy they are quit old.
devzone.nordicsemi.com/.../
The question is, do I need to set up two events or toggle? Any other idea?
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    in_config.pull = NRF_GPIO_PIN_PULLUP;
	err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
I wonder if I need separate handlers for two functionality?
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action){
		nrf_drv_gpiote_out_toggle(PIN_OUT);
		// IF BUTTON IS PUSHED
		if (action == NRF_GPIOTE_POLARITY_HITOLO){
			// DO SOMETHING
		// IF BUTTON IS RELEASED
		if (action == NRF_GPIOTE_POLARITY_LOTOHI){
			// DO SOMETHING
    The driver does not allow you to configure one pin for multiple actions, this will only result in an error.
    If you set PIN_IN to sense TOGGLE, you will get one event when the button is pressed and another event when the button is released. You can use a variable to keep track of the state:
    uint8_t button_pressed = 0;
        if(button_pressed == 0)
            NRF_LOG_INFO("Button pressed!\r\n");
            button_pressed = 1;
            NRF_LOG_INFO("Button released!\r\n");
            button_pressed = 0;
    Jørgen
