Hi
I use sdk 12.3 with custom board.
How to add a DFU service to the FREERTOS hrs example code?
Thanks.
Hi
Thanks.
please take a look at this thread. And the answer from Vidar.
Can you please edit the link it's not working anymore...
Thank you in advance
Hi Thorben
I am sorry but the link is not available anymore. Attached is a modified version of the example made by Vidar in the link you are after. It should support buttonless dfu, but note that it has not been thoroughly tested and is getting pretty old. nRF5_SDK_11.0.0_freertos_dfu_060516.zip
I suggest you use it as a guide to see how you can implement this in a newer example.
Simon
Thank you, i'll check that.
