accelerometer_result_error
Hello ,I wrote a program that allows to control the LIS2DE12 accelerometer but I am reviewing a fixed result which is always X = 72, Y = 33, Z = 32, I find out where the problem , thanks you in advance.
`int main(void)
	int8_t X,Y,Z;
    uart_config();
    //accel_I2C_datawrite(&twi_instance);
    twi_init();
     m_device_address = accel_addr;
    uint8_t rx_buffer[6];
   rx_buffer[0] = 0x00;
//int threshold;
//accel_set_threshold(threshold);
            while(true)
            accel_xyz_read(&X,&Y,&Z);
         printf("Groupeer accelero DATA2:  X: %d  Y: %d  Z: %d  \n", X ,Y,Z);
					nrf_delay_ms(1000);
  • Hello, you are right, I have a mistake in the function read.I tested it
      X = accel_I2C_register_read(m_device_address,access_data,( uint8_t *) WHO , sizeof(WHO));
    printf(" result is %x ,%d ",WHO, X);
    I find 17 instead of 33 107/5000 So I have not properly configure reading and writing, I will change the ones you recommended
  • Hello ,Here are the functions I used to read and write For the read I sent a '1' to allow read
    ret_code_t accel_I2C_register_read(uint8_t slave_addr, uint8_t reg_addr,  uint8_t * pdata, uint32_t bytes)
    ret_code_t ret_code; //to configured the I2C read ret_code = nrf_drv_twi_tx(p_twi_master,slave_addr, &reg_addr,1,false);
    if(ret_code != NRF_SUCCESS)
            return ret_code;
    ret_code = nrf_drv_twi_rx(p_twi_master,slave_addr, pdata, bytes);
    return ret_code;
    } ret_code_t accel_I2C_register_write(uint8_t slave_addr,uint8_t * pdata, uint32_t bytes) { ret_code_t ret_code;
    ret_code = nrf_drv_twi_tx(p_twi_master, slave_addr, pdata, bytes , false);
    return ret_code;
    Is what i have is correct?
  • Hi Amed, I have edited my answer
  • I thank you greatly for help, just when I changed the variable "uint8_t rx_buffer [6];" In variable globle the program accel read axes does not work
  • Hello, For the function accel_set threshold it does not work (it is the function that is responsible for the detection of interrupts: if there is a movement or not)
    int accel_set_threshold(int threshold)
    { m_device_address = accel_addr;
    int max_threshold = 127* THS_2G  ;
    uint8_t ths = threshold/THS_2G;
    uint8_t accel_reg[2];
    printf( "hors threshold \n");
    if (threshold > max_threshold) { printf( "Threshold out of range\n"); return -1; } else { accel_reg[0] = INT1_THS;
    accel_reg[1] = ths;
    accel_I2C_register_write(m_device_address,accel_reg, sizeof(accel_reg) );
    // accel_I2C_register_read(m_device_address,INT1_THS, &ths ,sizeof(INT1_THS));
    printf (" test"); printf ("Threshold @ %x(%d)\n",ths, ths);
    return 0;
    } Thanks
