accelerometer_result_error
Hello ,I wrote a program that allows to control the LIS2DE12 accelerometer but I am reviewing a fixed result which is always X = 72, Y = 33, Z = 32, I find out where the problem , thanks you in advance.
`int main(void)
	int8_t X,Y,Z;
    uart_config();
    //accel_I2C_datawrite(&twi_instance);
    twi_init();
     m_device_address = accel_addr;
    uint8_t rx_buffer[6];
   rx_buffer[0] = 0x00;
//int threshold;
//accel_set_threshold(threshold);
            while(true)
            accel_xyz_read(&X,&Y,&Z);
         printf("Groupeer accelero DATA2:  X: %d  Y: %d  Z: %d  \n", X ,Y,Z);
					nrf_delay_ms(1000);
  • Hello, I have a problem with the detection of the interrupt I use this code to detect the rising edge of the pin INT1`static void gpio_init(void) { ret_code_t err_code;
    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(false);
    in_config.pull = NRF_GPIO_PIN_PULLUP;
    err_code = nrf_drv_gpiote_in_init(PIN_INT, &in_config, in_accel_handler);
    nrf_drv_gpiote_in_event_enable(PIN_INT, true);
