SPIM deterministic TX timing control
Hi fellows,
I'm trying to control accurate/deterministic timing of the first bit from MOSI PIN of SPIM, employing EasyDMA.
According to Figure 69 SPI master with EsayDMA, SPIM block has "TXD+1". That would be double buffer for Tx. So, for accurate immediate timing control of MOSI signal, I would like to trigger SPIM to start Tx'ing while the first byte has already been on that double buffer, not under situation where nothing is pre-buffered by EasyDMA, because EasyDMA's bus activity will take addtional cycles.
And additionally, for accurate periodic/pre-scheduled timing control, I'm driving TASKS_START not by CPU but by Timer's EVENTS_COMPARE[i] routed thru PPI.
But, still, some timing jitter is observed on MOSI signal. What indeed is the cause of this timing jitter ? And, any other smart ways to do it accurately on time? Or, SPIM's TASKS_SUSPEND/RESUME can be used alternative to TAKS_STOP/START ?
  • Hi Turbo J,
    I got a small progress.
    In my older code, I was setting HFCLK after SoftDevice is enabled. ( I have seen CLOCK->HFCLKSTAT.SRC is unexpectedly flipped) Now, I did set HFCLK far before SoftDevice is enabled. Then, the most of the cause of the jitter disappeared.
    But, still timing jitter is observed on MOSI pin. When I connect ide debugger ULINK-Pro (but without Periodic Window update disabled), it works fine. But when I let it run stand-alone, only at the very limited duration, jitter appears. Very strange...
  • The reason you see this version as the latest in CMSIS pack installer is that we deprecated support for CMSIS Pack. You can download the no-pack version of the latest SDK from this page. You will find all relevant documentation on our infocenter.
1 2
