sd_softdevice_enable loop
I have a program that do an infinite loop in sd_softdevice_enable. How can i investigate ?
Loop is from 0x00009DEA to 0x00009DF2
Target is nRF52832 AA with nRF5_SDK_13.0.0_04a0bfd / s132_nrf52_4.0.2_softdevice.hex
  • What does nRF put to terminal? Maybe linker file need modification of RAM start address and size? If yes in terminal will be printed values to set.
  • I have tested on another board with a nRF52832, code works... but not on a Sparkfun nRF52832 board... strange. I have no USART on the faulty board this board, just JTAG. I will check tonight with RTT.
    Are you using the exact same code for the Sparkfun board? Make sure that you have flashed the correct SoftDevice. As mentioned by Luk3, a reset from sd_softdevice_enable() is usually caused by wrong RAM start address( error-code NRF_ERROR_NO_MEM(=4) ).
    Note that a reset indicates that you are running into the error handler, where the default behavior is to do a reset. You should then debug in order to find the reason for the reset. See this post about debugging.
  • Hello, this is exactly where it loop, do someone have an idea please ?
    // Initialize the SoftDevice handler module.
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL); <= infinite loop inside that
  • Maybe something is wrong LF clock source? RTT log could be really helpful. Check NRF_CLOCK_LFCLKSRC and try to switch to internal RC.
