I get soft reset when MTU is bigger than 65
Hello!
I am trying to increase the MTU size to get higher speeds. When I increase the MTU above 65 the application locks/software reset when doing transfer. Up to 65 it works. I have increased RAM memory for SoftDevice a lot. No difference. I check the return value of softdevice_enable(). Always zero. I have not enabled DLE.
65 sounds awfully close to 64, but it is still a bit strange value.
Any hints or tips would be appreciated
    What SDK version are you using? What example in the SDK are you testing this on?
    In e.g. SDK 13 in the ble_app_uart example you set the ATT_MTU with the nrf_ble_gatt_att_mtu_periph_set() function:
    void gatt_init(void)
        ret_code_t err_code;
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, 64);
  • General Note: A reset indicates that you are running into the error handler, where the default behavior is to do a reset. You should then debug in order to find the reason for the reset. See this post about debugging.
  • Hi Sigurd,
    I use SDK 12.2 (SD132).
    I do not test on any particular example, I do test it on our application directly. I try to speed up transfers and currently increasing the MTU seems to be the only viable way.
    I set MTU by:
    #if (NRF_SD_BLE_API_VERSION == 3)
        ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
        // Enable BLE stack.
        ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
        err_code = softdevice_enable(&ble_enable_params);
    I hope this is the way to do it in 12.*.
    I will check out the debugging post you refer to, thanks!
  • Are you handling the event BLE_GATTC_EVT_EXCHANGE_MTU_RSP ? and starting the ATT_MTU exhange with sd_ble_gattc_exchange_mtu_request() ? Take a look at the S132 v.3.0.0 migration document. "Configurable ATT_MTU" section contains information you need.
    You can also find an example on how to enable DLE and increase ATT_MTU for SDK 12 in this post.
  • Hi Sigurd,
    your debug suggestion worked. I have now found that the error comes from softdevice_handler.c line 187 and I get NRF_ERROR_DATA_SIZE (error code 12). I do not understand why.
    I will close this and open a new question, thanks for the help!
    /Stefan
