NRF ERROR DATA SIZE in from sd_ble_evt_get in softdevice_handler.c
I am trying to increase MTU size for transfers and it works up to a size of about 72. After that I get an error.
Thanks to Sigurd I now know that it is when calling sd_ble_evt_get() in nrf_sdk/softdevice/common/softdevice_handler/softdevice_handler.c (line 187) that returns error 12, which I have decoded to NRF_ERROR_DATA_SIZE.
There must be a place I have forgotten to set proper size and up to certain point it breaks.
Anyone having inputs or pointers?
Thanks!
    You shoud add the define NRF_BLE_GATT_MAX_MTU_SIZE in sdk_config.h, so that the size of BLE event message buffer is set correctly.
    In ble_stack_handler_types.h we have the following code in sdk12.2 that will set the buffer size based on NRF_BLE_GATT_MAX_MTU_SIZE /GATT_MTU_SIZE_DEFAULT :
    /** @brief  Default Maximum ATT MTU size.
     * This define should be defined in the sdk_config.h file to override the default.
    #ifndef NRF_BLE_GATT_MAX_MTU_SIZE
        #define NRF_BLE_GATT_MAX_MTU_SIZE GATT_MTU_SIZE_DEFAULT
    #define BLE_STACK_EVT_MSG_BUF_SIZE       (sizeof(ble_evt_t) + (NRF_BLE_GATT_MAX_MTU_SIZE))
  • Thanks Sigurd,
    Sorry for long time to answer, but I have now tested this and it works as far as I can test.
    I discovered that I am not using 12.2, but 12.1 or 12.0. But it was simple enough to add these lines to ble_stack_handler_types.h and get it running.
    Thanks again!
