nRF51822 - Proprietary Protocol - Using micro_esb library - Need Help Improving TX Function
Hey guys, I am currently using the proprietary protocol on the micro_esb.c library with the nRF51822. So far everything has been working great, but I am certain my transmission function could be improved.
Here is what I have so far:
void transmit_payload()
	uesb_stop_rx();
	uesb_disable();
	uesb_config.mode = UESB_MODE_PTX;
	uesb_init(&uesb_config);
	uesb_start_tx();
	uesb_write_tx_payload(&tx_payload);
	nrf_delay_ms(2);
	uesb_disable();
	uesb_config.mode = UESB_MODE_PRX;
	uesb_start_rx();
Notice the "nrf_delay_ms(2)", if I don't have that there, the payload will not transmit, and I will not get a TX success interrupt.
The problem is that the device is mostly sitting in RX mode, receiving payloads. It periodically switches over to TX mode to transmit some payloads. Because of how I have it set up, it basically takes 2ms per payload, which is way too long to be not in RX mode (since the device will miss payloads while in TX).
I have a stack full of payloads that are queued up in memory, so when its time to transmit, its calling this function for each individual payload that needs to go out.
Are you aware of a better way of doing this, or a better function? I'm imagining if there is a way I could switch over to TX mode, and send off a whole bunch of payloads, then switch back to RX mode, instead of switching back and forth for each individual payload.
Can I just use the "uesb_write_tx_payload" function multiple times, and keep track of how much time has gone by, and if it has not exceeded 2ms yet after multiple calls, then add in delays?
Thanks and any help/advice is greatly appreciated!
