Good morning I use the fds function to store and read data in flash memory. FDS_SUCCES is not returned by the fds_record_find function when reading data, so the read function does not work Help me solve this part Below is my code
#include "sdk_config.h"
#include "uuid_data.h"
#include "app_error.h"
#include <string.h >
#include "app_util.h"
#define FILE_ID 0x1111
#define REC_KEY_ID 0x2222
static void fds_evt_handler(fds_evt_t const * const p_fds_evt)
switch (p_fds_evt->id)
case FDS_EVT_INIT:
if (p_fds_evt->result == FDS_SUCCESS)
// Initialization failed.
printf("init success \n\r");
case FDS_EVT_WRITE:
if(p_fds_evt->result ==FDS_SUCCESS)
printf("write success \n\r");
ret_code_t beacon_uuid_storage_init(void)
ret_code_t ret = fds_register(fds_evt_handler);
if (ret != FDS_SUCCESS)
// Registering of the event handler has failed.
ret = fds_init();
// Handle error.
return NRF_SUCCESS;
ret_code_t uuid_storage_write(uint16_t file_id,uint16_t key, uint8_t const *p_data,uint16_t length)
fds_record_t record;
fds_record_desc_t record_desc;
fds_record_chunk_t record_chunk;
record_chunk.p_data = p_data;
record_chunk.length_words = BYTES_TO_WORDS(length);
record.file_id = file_id;
record.key = key;
record.data.num_chunks = 1;
record.data.p_chunks = &record_chunk;
ret_code_t ret;
ret = fds_record_write(&record_desc,&record);
if(ret != FDS_SUCCESS)
printf("write fail \n\r");
return ret;
else if(ret == FDS_SUCCESS)
return ret;
ret_code_t uuid_storage_read(uint16_t file_id,uint16_t key,uint8_t *p_data)
ret_code_t ret;
fds_flash_record_t flash_record;
fds_find_token_t ftok ;
memset(&ftok, 0x00, sizeof(fds_find_token_t));
while (fds_record_find(file_id, key, &record_desc, &ftok) == FDS_SUCCESS)
printf("read success \n\r");
ret = fds_record_open(&record_desc,&flash_record);
memcpy(p_data , flash_record.p_data , (flash_record.p_header->tl.length_words * BYTES_PER_WORD));
ret = fds_record_close(&record_desc);
printf("close fail \n\r");
return ret;
return ret;
ret_code_t uuid_del(uint16_t file_id,uint16_t key)
fds_record_desc_t descriptor;
fds_find_token_t ftok = {0};
ret_code_t ret = fds_record_find(file_id,key,&descriptor,&ftok);
ret = fds_record_delete(&descriptor);
printf("del fail \n\r");
// Error.
