How to use nRF Connect v2.0 behind corporate SSL proxy?
Hi, Congratulations on releasing nRF Connect v2.0!
Unfortunately, I'm having trouble with adding apps behind corporate SSL proxy. Is there a workaround for this? Please consider adding feature for proxy configuration and adding trusted root CA certificates. Best regards, Zoltan
yarn-error.log
UPDATE:
After some trial and error I found the correct configuration for Yarn. Some comments:
  • If you don't have Yarn installed, the .yarnrc file needs to be created manually and Yarn seems to require a certain file format (extra blank lines);
  • Depending on your SSL proxy, multiple cafile entries may be necessary;
  • The certificate file should have base-64 encoded X.509 format;
  • If you need to specify the domain in your proxy credentials, url-encode the separating backslash with %5C.
Config example for Windows:
.yarnrc
