NRF_ERROR_NO_MEM
I'm developing a FW with a lot of services and characteristics. Since I added the ANCS service, I have the "NRF_ERROR_NO_MEM".
Configuration : NRF51822_XXAC / S130 V2 / custom secure bootloader + DFU / Segger embedded studio / bootloader setting file to allow programing without DFU.
Section placement macro (Embedded studio) : FLASH_START=0x1b000 SRAM_START=0x20002008
I read a lot of things about this error : increase the size of the gatt table, adding "BLE_GATTS_VLOC_USER"...
Like explained on the migration guide, I checked the expected RAM size. The debug result is described below :
SDH:DEBUG:sd_ble_enable: RAM start at 0x20002008 SDH:DEBUG:RAM size should be adjusted to 0x5ff8 SDH:DEBUG:sd_ble_enable: RAM start should be adjusted to 0x20002008 :INFO:running nrf_dfu_settings_init APP:INFO:app_error_fault_handler : id=0x00004001, pc=0x00000000, info=0x20007f64 APP:INFO:err_code 00000004 in line 298 of XXXANCS/ble/ble_services.c APP:INFO:-> NRF_ERROR_BASE_NUM
I changed the SRAM size and attr_tab_size but after that, the application doesn't start like if the bootloader doesn't know where to find the application start address. Do I have to change something in the bootloader or something else that I missed?
Thank you
  • More details about the NRF_ERROR_NO_MEM error source. This one is happening when the sd_ble_uuid_vs_add(&ble_ancs_cp_base_uuid128, &p_ancs->service.control_point_char.uuid.type) is called. I saw some topics about modifying the VS_UUID count.
    If I change SRAM_START, attribute table size or VS_UUID count, it seems that the App doesn't start. The actual bootloader is a release and there is no debug function. I have to activate NRF_LOG to debug. I'm on it but I have some compiling issues with the makefile that I have to fix...
    The placement macro in Segger embedded studio is : FLASH_START=0x1b000 SRAM_START=0x20002008
    Do you need more information ?
