Hello:
I'm trying to get an example program ble_app_hrs running on my custom board, because earlier last month I couldn't write the cccd descriptor properly and I suspect there is something buggy on the board side, and I'm trying to see if official examples will run on my board properly.
So I'm using the nRF5_SDK_13.1.0_7ca7556 example, and the s140_nrf52840_5.0.0-2.alpha softdevice which comes within the 13.1.0_7ca7556 package.
I can manage to get the program run to softdevice_handler_init, shown in the picture below:
and from this point on, I'm stuck in an ls loop forever, here's the code:
#PART 1
0x00009F3E 2800 CMP r0,#0x00
0x00009F40 D0FA BEQ 0x00009F38
#PART 2
0x00009F38 4630 MOV r0,r6
0x00009F3A F008FC57 BL.W 0x000127EC
#PART 3
0x000127EC 4906 LDR r1,[pc,#24] ; @0x00012808
0x000127EE 310C ADDS r1,r1,#0x0C//after this, r1 will have value of 0x40000418
0x000127F0 680A LDR r2,[r1,#0x00]//the value read from 0x40000418, which is LF STATUS register, is 0x00010001
0x000127F2 03D2 LSLS r2,r2,#15
0x000127F4 D506 BPL 0x00012804
0x000127F6 6809 LDR r1,[r1,#0x00]
0x000127F8 F0010103 AND r1,r1,#0x03
0x000127FC 4281 CMP r1,r0
0x000127FE D101 BNE 0x00012804
#PART 4
0x00012804 2000 MOVS r0,#0x00
0x00012806 4770 BX lr //which goes back to 0x00009F3E, the beginning of this loop.
By reading through this loop, I found something problematic:
A. there is no code which could possibly break out of this loop, is this a hardfault handler of some sort? See a more complete #PART 3 here:
0x00012800 2001 MOVS r0,#0x01
0x00012802 4770 BX lr
0x00012808 040C LSLS r4,r1,#16
0x0001280A 4000 ANDS r0,r0,r0
0x0001280C 49C8 LDR r1,[pc,#800] ; @0x00012B30
0x0001280E F8110F21 LDRB r0,[r1,#0x21]!
0x00012812 7849 LDRB r1,[r1,#0x01]
My assembly-fu isn't high enough so I could be wrong. Anyway the code looks very much like it tries hard to see if the LF clock was properly configured, which brings up problem B.
B.Unable to change the source of LF clock: as you can see from the above assembly code comment, the value of 0x40000418 is 0x00010001, it means 1. the lf clk is running, 2. the source is xtal 36.768, which is really, really weird because I don't have any external lf crystal mounted and I'm positive that I've set the source to RC, in the code below:
This is all very weird, I want to enable the sd, but couldn't, what should I do next?
Best regards!
