I an trying to wake the chip and record the temperature readings when temperature reaches a certain threshold (eg: 80 deg C), can this be achieved using built-in temperature sensor? Has anyone successfully implemented something similar?
Regards, Sid
Regards, Sid
Hi Sid,
I'm not sure how LPCOMP and ANADETECT relates to your question, but there is no configurable wake-on-temperature-threshold in the built-in TEMP peripheral. You will have to use a timer/RTC to start the temperature sampling on a regular interval, to check the temperature.
Jørgen
