pstorage write process failed with s110
hi,
i have tried to write data into flash memory, but i can not, i can read the data from memory.
i had followed your instruction as this link
infocenter.nordicsemi.com/index.jsp
and some other solutions like this following thread
devzone.nordicsemi.com/.../
as per above thread i used 30ms delay aslo.
please any one help me,
note:-
i had used RTC1 interrupt with every 5ms for real time clock to generate current date and time.
This my source code,
uint32_t mem_clear(int block_num, int page_num)
	uint32_t nReturnValue;
	int i=0;
		nReturnValue = pstorage_block_identifier_get(&block_id,block_num,&block_0_id);
			if (nReturnValue != 0)
					return INTIAL_GET_TYPE_WRONG_3;
			 for (i=0;i<page_num;i++)
				 	nReturnValue = pstorage_clear(&block_0_id,1024);
           block_0_id.block_id += 1024;
					 nrf_delay_ms(30);
					 		return INTIAL_GET_TYPE_WRONG_4;
uint32_t read_from_mem(unsigned char *des,int block_num, int size, int offset)
		if(nReturnValue != 0)
				return GET_SYSTEM_PASSWORD_BLOCK_ID_ERR;
		nReturnValue = pstorage_load(&des[0],&block_0_id,size,offset);
		if (nReturnValue !=0 )
				return GET_SYSTEM_PASSWORD_FAIL;
		nrf_delay_us(500);
	return nReturnValue;
uint32_t write_from_mem(unsigned char *src,int block_num, int size, int offset)
				return false;
		nReturnValue = pstorage_store(&block_0_id,&src[0],size,offset);
			nrf_delay_ms(30);
				return false;
static void example_cb_handler(pstorage_handle_t  * handle,uint8_t op_code, uint32_t result, uint8_t * p_data, uint32_t data_len)
	if(handle->block_id == pstorage_wait_handle) { pstorage_wait_flag = 0; }  //If we are waiting for this callback, clear the wait flag.
	switch(op_code)
			case PSTORAGE_LOAD_OP_CODE:
				 if (result == NRF_SUCCESS)
						 nrf_delay_ms(1);
						 nrf_delay_ms(1);
			case PSTORAGE_STORE_OP_CODE:
						nrf_delay_ms(1);
						nrf_delay_ms(1);
			case PSTORAGE_UPDATE_OP_CODE:
						nrf_delay_ms(1);
						nrf_delay_ms(1);
			case PSTORAGE_CLEAR_OP_CODE:
						nrf_delay_ms(1);
						nrf_delay_ms(1);
			case PSTORAGE_ERROR_OP_CODE:
						nrf_delay_ms(1);
