sd_ble_evt_get questions
  1. I'm seeing the sd_ble_evt_get return NRF_ERROR_DATA_SIZE even though the supplied buffer and length param are larger than the event length. Is this a known benign issue?
If the following code
rc = sd_ble_evt_get(NULL, &evt_len); evt_buff_len = evt_len; // evt_buff_len = evt_len + 4; <-- in case evt_len is 0 rc = sd_ble_evt_get(myBuffer, &evt_buff_len);
if the evt_len returned is 0, rc is 12 or NRF_ERROR_DATA_SIZE Even if the evt_buff_len is set to 4, the rc is NRF_ERROR_DATA_SIZE
All other times, the rc is 0 (NRF_SUCCESS).
when there is no prior call the get the event length - following is executed in the same scenario as the above code rc = sd_ble_evt_get(NULL, &evt_len); evt_buff_len = 60; rc = sd_ble_evt_get(myBuffer, &evt_buff_len);
rc is NRF_ERROR_DATA_SIZE more often than when the size was originally obtained even when the evt_len is known to be smaller than the evt_buff_len.
  1. What is the max time that can elapse before I invoke sd_ble_evt_get to get an event from the BLE stack?
Thanks
  • Hi David,
    1. Is there a reason why you're not using the softdevice_handler library which is included in the SDK? This takes care of these things for you, as you may run into these issues if your buffer is not word-aligned in memory.
    2. This will depend on your link and your requirements. You can queue events, and just keep on pulling them until you get return code "NRF_ERROR_NOT_FOUND".
    Best regards Håkon
  • The buffer is word aligned in memory. This was validated early on.
    There would have been other issues if it had not been to put things mildly.
    The main reason for using the event get function is that we have our own interrupt handler.
    What suggestions would you have to incorporate the soft device_handler library with existing interrupt handler mechanisms that a developer has?
    David
  • i realize this is dated, but what was the resolution? were you able to fix? i am experiencing a similar issue: NRF_ERROR_DATA_SIZE return from sd_ble_get_event with word aligned buffer with event smaller than buffer size. the setup and processing looks to be identical ti the soft device_handler implementation in the sdk and examples.
