How to implement soft uart in Pca10028?
I am using pca10028 and sdk 12. I want to use 2 uart for my application but as per datasheet nrf51 has only one hardware uart. Can I implement soft uart on pca10028? I want to use both the uart at the same time so multiplexing will not help me.
Sdk_config.h New Text Document (3).txt
Main.c New Text Document (3).txt
Thanks, Shailav
  • You should use the NRF_LOG_INFO macro instead of SEGGER_RTT_printf() , e.g.
    NRF_LOG_INFO("Heart Rate Sensor Start!\r\n");
  • Hi, I am unable to see any output using NRF_LOG_INFO. I am attaching my sdk_config.h file and main.c file above. Thanks
  • You also need to either set NRF_LOG_DEFERRED to 0 in sdk_config.c or call NRF_LOG_PROCESS() in the main while loop.
  • Hi, I am able to print something on RTT_viewer by implementing your suggestions but I also want to print the mac address, Rssi and adv data of nearby ble devices as I am using ble_app_uart_c(central) code. I am not able to see above data in rtt_viewer. My code snippet is as follows
    const ble_gap_evt_adv_report_t * p_adv_report = &p_gap_evt->params.adv_report;
             // scan is automatically stopped by the connect
                 NRF_LOG_INFO("Mac address %02x%02x%02x%02x%02x%02x\r\n",
                   p_adv_report->peer_addr.addr[5],
                   p_adv_report->peer_addr.addr[4],
                   p_adv_report->peer_addr.addr[3],
                   p_adv_report->peer_addr.addr[2],
                   p_adv_report->peer_addr.addr[1],
                   p_adv_report->peer_addr.addr[0]
    		NRF_LOG_INFO("Data: ");
    	        for(i=0;i<17;i++)
    		     NRF_LOG_INFO("%02x", p_adv->data[i]);
    		NRF_LOG_INFO(" \r\nRSSI: %d\n", p_adv->rssi);
  • So none of the NRF_LOG_INFO calls under the BLE_GAP_EVT_ADV_REPORT case in on_ble_evt() shows up in RTT viewer? Did you set NRF_LOG_DEFERRED to 0 or did you call NRF_LOG_PROCESS() in the main while loop?
