Antenna selection?
Hi Sir,
I am using nordic nRF51822 IC for Tracking Application for that Which antenna is best ?
I have seen two type of antenna .
  1. zig zag pcb antenna
  2. straight pcb antenna
so please give the suggestion ,which is suitable for this application.
  • The pros and cons of the two antenna layouts are listed below. It basically boils down to how much space you have on your PCB.
    ¼ Wave PCB Antenna
    • Easy to implement
    • Easy to tune (length and/or external components)
    • Relatively large
    • Not 50 ohm initially (36ohm at resonance)
    • High bandwidth
    • Best solution if space is not a issue
    Meander Antenna
    • Small, but has less gain
    • Must be tuned (length and/or external components)
    • Lower bandwidth than a ¼ wave antenna
