Is it possible to change the output power of the Thingy to +4dBm and how would one do that.
We are using the Thingy for demos and would like to demonstrate the difference in power output and also show a max range with the Thingy
Hi Shanestarita!
Yes, it should be possible to change the transmit power to +4dBm.
As you can't change it via the Nordic Thingy:52 App, you would have to add it to the code.
You can change the transmit power using the sd_ble_gap_tx_power_set() funtion.
Regards
Joakim
