My sensor uses SPI communication and need 32.768kHz external clock pin FCLK , I connect 32.768kHz clock to XL1 and XL2 but my problem is which pin can I use it for FCLK ?
What kind of SPI needs a frame clock? The SPI supported on the nRF series is normal SPI, just clock and data.
Could you provide a link to the datasheet of the sensor you're using?
I'm not convinced reading that data sheet that FCLK has to be synchronous in which case you could generate it separately and pipe it in.
